| :The throttle bodies are different. The ones on the TT are designed for the TT plenum. Has an extra coolant line that goes out of it that the n/a throttle bodies don't. Now that I think about it, the throttle body shaft seals are different, in that they aren't designed to handle boost :And I heard something about the clutch booster is different? :Thanks for your quick response. Can you swap over the fitting from your TT manifold for the clutch booster?
